Question Toshiba Laptop Battery BMS Reset
Sep 24, 2020
Hi everyone. Thanks in advance for your help. I have a question for all.
I have aToshiba PA3534U-1BRS (Satellite A505-S6012) battery pack, it was completely dead.
I have changed old cells, new2 ones was installed, but the battery still not charging.
There is some way to reset the BMS IC? I tried all the ways that found on YouTube and google, with no results.
By the way, there is a thermal Fuse between 2nd and 3rd pack, I must replace it for a wire, because it was opened in cold, and hot y can obtaind 2V from the 12V of the pack.
Thanks all for your time.
Regards.-
