Try the following....
If your microphone isn't working, try the following...
1. Go to "Control Panel".
2. Click on "Sound".
3. Click the "Recording" tab.
4. Click on the device you are trying to fix.
5. Now click the "Configure" button and then click "Set up Microphone".
6. Once that is complete, click the "Properties" button.
7. When you are done with your changes, in "Properties", click "Apply" and then "OK".
8. Then click "OK", again, on the main "Sound window".
Also... If your speaker/headphones aren't working, try the following...
3. Make sure you are on the "Playback" tab.
5. Now click the "Configure" button and follow the prompts. (Be...
