[SOLVED] Toshiba Satellite C660-10D Turn On Problem
Chkontog
96
Hi, i have a toshiba satellite c660-10d and when i turn it on, then the cpu fan sounds a little and then goes out.Νeither the bios nor anything is visible.What could be wrong?
remove battery and power cable, press power button for 30sec. Put only power cable back and try to start. if it wont work then check your getting enough voltage from your power brick with multimeter or try another charger.
few seconds and power off usually is cause of component failure in the motherboard but might be other things too.
