Toshiba Satellite C660 not powering up.
yonutzjo
8
I have some issues with a toshiba c660. Well, I was installing some drivers today, and it decided to just freeze, so I tried turning it off. Didn't work, so I had to unplug the battery. Now, plugged it back in, and nothing, it doesn't even turn on. I get no lights on it at all. Nothing. Tried holding down the power button to reset it, tried using only the charger plugged in. I have no idea what to do, please, I need some help D:
1) Unplug the power cord --> Remove the battery --> Hold the power button for
60 seconds --> Connect the power supply then try to switch ON the laptop and
later put the battery back into the laptop.
2) If the problem still exists then click on the below link and follow the instructions
http://en.kioskea.net/faq/9066-display-problem-laptop
(http://en.kioskea.net/forum/affich-671820-toshiba-laptop-satellite-c660-not-booting-up)
I did take a look on the internet, and tried that too. I might have to open it and take a look inside. What could be causing this though? I get no power at all. Not even the fan starts spinning.
If those steps did not work for you then it may be a hardware failure. Are there any lights when plugged in showing you that? If not then it is almost certainly a hardware failure.
Nope, no lights at all. Any ideas on what part might be dead/malfunctioning?
This option really worked after whole day of troubleshooting in my workshop Connor is a GEEK. thumbs man
