PROBLEM: No video. No beeps (even removing RAM, no RAM problem beep). When you turn it on: fan turns on for a second then turns-off and all is silent, caps-lock light doesn’t turn on. Doesn't work with battery alone. Three lights turn on in the front-left panel DC-IN: green, POWER ON: green, MAIN-BATTERY CHARGING: amber), then if you press the power button for a few seconds, the Power-On light turns off. No video when connecting an external monitor cable, even after pressing the F5 key, which seems to be intended for external monitor. USB closest to screen (CD-Drive side) is missing (you can see the hole but not the inner tab).
