S skolluru Prominent Mar 5, 2017 1 0 510 Mar 5, 2017 #1 Laptop powers down completely when AC power is cut though the battery is showing 100%. Toshiba Satellite L55W- C5220. I also down loaded the BatteryMon (Monitoring Battery) and it indicates that the battery is good and has life.
Solution atljsf Mar 5, 2017 if the battery or the indicator in the battery are not working, well, you need a new battery if you get a new battery and does the same, it is the laptop
atljsf Honorable BANNED Jun 17, 2015 4,910 46 12,990 Mar 5, 2017 Solution #2 if the battery or the indicator in the battery are not working, well, you need a new battery if you get a new battery and does the same, it is the laptop Upvote 0 Downvote Solution
