Toshiba Satellite Laptop died on ac adapter only, no battery pack with two blinking lights
ryuzakiazri
my laptop died suddenly under different conditions.. but normally when im playing dota2 or dragon nest.. sometime its okay to play on high graphic settings. im not using battery pack. only ac adapter. when it died it shows two blinking orange lights. i had to pull out the adapter then turn it back on. and i tried the 30 sec power button. i still dont understand what caused the laptop to turn off suddenly.
Try a reset... remove battery and from AC. Press and hold power ON button for 30secs at least. Put back battery back and plug into AC then Power ON as normal.
hurmm.. i got the same problem.. even though after change my thermal paste and using cooler master cooling fan, the same problem happen.. is this problem related to chipset problem??
