Toshiba Satellite No Display Black Screen but External Monitor Works
Annabelle Droyd
System:
Toshiba Satellite L655D-S5050 - Windows 7 - 4GB RAM - AMD Anthlon II 2.1 GHz Dual Core - Radeon HD 4250
Problem:
No display at all - just black screen. No logo screen or anything when powering on.
Scenario:
One day I picked up the laptop to use after it had went into sleep. Display would not come on, powered off and back on twice before it would work.
Last week, my husband was using it for online shopping. He logged off his account, closed the lid, it went into sleep. I opened it up to use it and the display would not turn on. I powered off and back on, still no display.
Troubleshooting Steps Taken:
1. Removed battery, power cable, held down power button for 60 seconds, re-insterted battery and cable - **no success**
2. Shine light into display- I do not see anything **no success**
3. Insert windows disk **no success**
4. Connected an external monitor- **Works** (External one works, laptop one does not)
5. Change BIOS setting "Dynamically Switchable" to "Always Low"
Note: I don't know what that does, I read it in a forum and tried it.
6. Replaced cable from display to motherboard and also the LCD screen - **no success**
Note: I went ahead and replaced the screen as the screen that came in it had a few flaws and I intended to replace anyway.
7. Shine light into display again- I do not see anything **no success**
8. Replaced RAM (Already had some RAM so why not try?) **no success**
Although the external monitor works, could this still be a faulty motherboard? Motherboard is quite expensive so I want to rule that out completely first before purchasing another one.
I'm at a total loss here and have spent literally hours trying to fix so any help would be greatly appreciated. I can get around on a computer good, know how to change parts, etc but still am no expert. I am hoping I am missing something simple! Help??!!!! Thanks!
Hi
Thank you for giving a clear description of what you have done so far to fix problem
I presume you are aware you can send video graphics output to internal LCD or external screen or both at the same time
By pressing 2 keys
There is a symbol on a function key that looks like a square screen
Press Fn key plus this key changes where video output goes
This setting gets remembered
I hope problem is simple one not faulty motherboard
Regards
Mike Barnes
Hi
By pressing 2 keys
Regards
Mike Barnes
Hi Annabelle,
I have very similar problems with my toshiba.
Did you get this solved at all? Any info would be much appreciated.
Cheers.
-Fauzer
I too have ran into this problem doing the exact same thing that you have with the same results. If anyone finds a fix to this please post
Latest posts
