Toshiba Satellite T135 not powering up, ust a quick power button light
Maria25
4
I have read almost of the thread here about this issue I got on my laptop but still can't fix. Anyways when I turn on the laptop with the battery and the charger I just saw the light of charging and when I press the power button, only a quick light up on the button and goes off again,no fan spinning,no harware sounds, I tried the common repair like removing battery and hold the power button for 30secs and put back the ac adapter and power it up still like that. what should be the problem? should I need to replace the motherboard or what??? Please HELP!!!!
Hi thank you for your respond @mrdolphinsboy, my laptop is charging and also when I put out the battery and leave the laptop with the AC adapter same thing happen, just a quick light for the power button and the LED lights at the bottom. I don't hear the fan running and the HD spinning.
I think that your best bet would be to just go to a goodwill or pawnshop and charge one of their batteries and try it there that way if it works you can buy it but if not then you know that it is another problem, but would have wasted no money. Besides this the only thing that I can think of.
One last thing to try before all this is to take out the battery and put it back in...
If the problem isnt the battery then i am not sure what it could be...Sorry but I can only say that your best bet is to take it to a repair shop..
