toshiba smart tv wont connect to wifi.
superkaare
I got a toshiba l3 smart tv, the other day. I tried connecting it via ethernet cable, and it worked fine. But when i put a wifi dongle in it, it said that "wifi dongle not detected". The dongle is a high-gain 150 Mbps PW-DN4210D. please help. any advice will work.
You can't use any USB wifi dongle. It must be an adapter supported by your TV, and more than likely a Toshiba-made adapter. Check your TV's user manual.
Alternatively, if your TV has an Ethernet port, you should be able to use a standard wifi bridge.
