Toshiba Speakers Blown help :(
Raven_11
hi i have a toshiba P75-A7200 and there is a crackling sound on the left speakers when I get my volume to 50+ any resolve on this. and is it really true if i use glue in the speakers it will solve the problem?
If your speaker is really blown, then nothing apart from replacing it will fix it. You could try giving the speaker a clean as sometimes you can get very small metal filings that stick to the magnet and hold the diaphragm down, thus bringing distortion when the voice coil has to move more (ie at higher volumes)
Using glue will not fix it and is likely to make it worse and inaudible, as the diaphragm will not move correctly. Especially for high frequencies.
Hope this may help!
K.
Hope this may help!
K.
