Question [Totally desperate] BSODs "KMODE EXCEPTION NOT HANDLED"
Jun 18, 2024
CPU: Ryzen 5800X
CPU cooler: Noctua DH 15
Motherboard: Asus B550-F Gaming Wifi II
Ram: Corsair Vengance 2x16 GB 3600 Mhz RGB KIT
SSD/HDD: Samsung 970 Evo
GPU: Nvidia RTX 4060 TI
PSU: Corsair RM750X
Chassis: NXZT Flow
OS: Windows 11 Pro
Monitor: LG 144Hz WQH something something
*sigh*
Hi everyone,
I'm actually tired of writing forum posts. I have a problem no one could help me with (so far). So I'm turning to the real pros this time.
I keep myself short: I get the 0000x1E "KMODE_EXCEPTION_NOT_HANDLED" error. Constantly. The error one screen gives me 0 hints because its always just the kernel that fails allegedly. So I have nowhere to start, Especially while gaming Here is the DUMP file: https://we.tl/t-Jha9k5g8LI
People tell me to check my ram, reset bios, ddu with nvidia driver update,etc. etc. I did all of that. Nothing helped so far. - I have the newest nvidia driver installed. It does happen with EVERY nvidia driver so far. Some nvidia drivers crash less others do more. I replaced my memory now TWICE! I have three memory kits here. Doesn't matter which one I use. The crashes keep happening. I have tried disabling everything that i could disable in my bios, All Overclockings are disabled. I have painstakingly gone through Device Manager and tried updating every driver that I could by hand.
Maybe you guys find something in the dumps. I'm... well. Desperate.
Thanks in advance for trying.
Using WinDBG, I see;
ntkrnlmp.exe
is what shows up.
Where did you source the installer for your OS?
You seem to be misunderstanding that the etc's only cover up what you've done. In doing so we can't tell what you've tried before creating your account here and this forum post. Once we know what you've tried, we can suggest what you can do further.
You use DDU in Safe Mode, then remove all GPU drivers(intel, AMD and Nvidia) then manually reinstall with the latest version in an elevated command.
You should have X.M.P/D.O.C.P enabled at the very least with two sticks of ram from the same brand, in your instance make sure you're not mixing and matching different revisioned PCB's from Corsair. Yes Corsair is the only brand that has PCB revision numbers on their ram kits since they source IC's for their ram off of multiple vendors.
every time i click that link it wants me to sign up to their service, can you upload to somewhere like google drive or onedrive and share that link (have to make sure its open to anyone with link
Seems it thinks - because other people have used it for BSOD before - that I want to use for my files and now won't let me use it.
