Tough problem with memory ?!?
alexzive
Hello everybody,
I'll be thankful to anybody who can help me.
Problem: under SUSE, filesystem gets automatically in read-only modus + CPU saturated. System hangs when it turns to the screensaver, cannot log-in anymore. HD (in RAID05) already checked, seems not to be the problem.
Maybe MEMORY.
getting >this error< with the firmware test provided on the SUSE-Install.CD
>Here< the options I can modify in my PhoenixbiosBIOS
Many thanks for help!
Alex
SYSTEM-INFO:
Xeon dual core 64bits
Intel(R) Xeon(R) CPU 5160 @ 3.00GHz
Raid controller Adaptec 2820SA
HD: 6x 250 Gb SATA2
IDE: 1*2 UDMA 100
MB: Supermicro X7DA8
Memory details
# dmidecode 2.9
SMBIOS 2.4 present.
Handle 0x0018, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0017
Error Information Handle: No Error
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank1
Type: DDR2
Type Detail: Synchronous
Speed: 533 MHz (1.9 ns)
Manufacturer: Not Specified
Serial Number: Not Specified
Asset Tag: Not Specified
Part Number: Not Specified
Handle 0x0019, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank2
Type: DDR2
Handle 0x001A, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank3
Type: DDR2
Handle 0x001B, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: 1
Locator: DIMM x 2
Bank Locator: Bank4
Type: DDR2
lott11
33
more then likely it is your graphics card controller.
There is great problem with built in Intel graphics they are known cause problem change to and earlier version of drivers, this will correct the problem, it happen SUSE 9.1 up 10.2 and 11.1 same Ubuntu , Red hat 8-9-10 Intel has released some drivers, but there still problems with some of there hardware.
