Tower on - No monitor signal
Apr 12, 2018
Hi guys,
I put together a custom PC last light and I'm having a few issues.
Specs -
CPU: Intel Core i3-8100
GPU: Msi GTX 1050 2GB
RAM: Corsair Vengeance 8GB DDR4
PSU: Thermaltake RGB 650W 80+ Bronze
So basically, when I power on the computer, everything works. All the lights on the mobo, all the fans and gpu lights. But, nothing shows on the display. Also, when i plug in a USB Flash drive, the usb lights up but when a keyboard is plugged in, it doesn't work. I've tried with both HDMI and DVI-D.
I have connected a different psu into the computer to make sure it still started and it did. I also connected my PSU into an older computer and it started.
There are no beeps from the CPU and everything is how it should be.
Thanks
