Tp-link power line and sagemcom router compatibility problems
Sean_5
I recently changed from normal broadband to fibre. I have always successfully used Tp-link 200mps power line adapters. They now don't work. I checked them at a computer shop and they are fine. My Sagemcom router connects fine when linked directly to the computer using a cable, just not through the power line.
Any ideas?
Powerline network adapters are transparent to the network. I would start with all new ethernet cables. Most likely cause is a bad cable. Start with everything close together -- both powerline adapters on a non-surge power strip. That will ensure that your two adapters get the best signal between them.
