[SOLVED] TP-Link TX50E AX3000 WiFi 6 & Bluetooth 5.0 PCIe Wireless Adapter
May 27, 2021
I'm planning on getting a TP-Link TX50E AX3000 WiFi 6 & Bluetooth 5.0 PCIe Wireless Adapter. but I don't know what cable or the amount of pins it uses. As well as If it would fit on my Msi Z170a m3 motherboard. Any Information would be helpful
It will fit if you have a PCIe x1 slot open and needs Windows 10. See HERE.
You won't get a lot of benefit from it unless you also have a router of similar abilities or plan to get one though.
