Question TP-Link Wireless (TL-WDN4800) issues
Hello
Many time drivers that work on Windows 7 and Windows 8/8.1 are also compatible with Windows 10.
You check the discussion and follow the solution given here.
If you're still unable to get it to work, you can use any third-party driver database like DriverPack Solution, SlimDrivers, etc.
Hope this helps.
Cheers!!
I appreciate the help but none of those drives you linked me from TP Link helped & I tried them before coming to the forums for a resolution. However, I will try DriverPack & SlimDrivers but I totally forgot about SlimDrivers program.
