Archived from groups: alt.games.tombraider (More info?)
Hello,
I installed TR1 under XP pro and glidos and all is ok (used the rush .exe file),
but can't find the way to make TR UB to work. I downloaded the 3dfx from
stella's site (I don't have the gold cd) and copied the exe file into the
tobraider directory (is this correct?) but then when I try to start TR UB from
glidos I have a message telling that the cd can't be found (but it is in...),
and can't find a solution. What is wrong?
Regards
Roberto
Hello,
Regards
Roberto
Thanks!
