Transcend 4gb 1333mhz ddr3 (16 cells) and Transcend 4gb 1333mhz ddr3 (8 cells) problem
deka_ns
Commendable
Dec 1, 2016
Hi guys i have big problem i have 1 module of Transcend 4gb 1333mhz ddr3 (16 cells) and 2nd one Transcend 4gb 1333mhz ddr3 (8 cells) , my motherboard is asrock g41m-vs3
as rock telling me
Memory - Dual Channel DDR3 memory technology
- 2 x DDR3 DIMM slots
- Supports DDR3 1333(OC)/1066/800 non-ECC, un-buffered memory
- Max. capacity of system memory: 8GB*
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
**In order to maximize the system memory, please install 4GB memory module with 16 cells or 2GB memory modules with at least 8 cells.
So , i can't boot my pc when i put this module with 8 cells , is there any way to somehow set up my bios or something else so i can boot my pc and work on it, please help me.
Dec 19, 2020
the 4gb stick should be with 16 cells.. if it's not, it should not work with G41s.. i faced the same problem
i tried with Asrock G41C-GS R2.0 and with Asus P5G41T-M LX.... same thing.. all i did was buy new ram sticks 2x4gb.. with 16cells un-buffered.. and it was working
USAFRet
139,191
7,414
166,440
21,427
4 years later....
I hope the OP is still not messing with this.
Please don't dredge up ancient threads.
