Transcend 8gb ddr3 1333 not working in dh55tc
Kishore_3
I brought a new transcend 8gb ram for my pc which already had 2gb kingston ram.
The problem is when i insert 8 gb Transcend individually or along with the 2gb It is not working , it will only load until the boot screen, and it restart again
But the 2gb ram works when i Insert it individually
The following are the details of my RAMs and pc :
Old RAM : Kingston 2gb 1333MHz
New RAM: Transcend 8gb 1333Mhz
*both RAMs are double sided
Processor : Intel i3 540 (3.07 Ghz)
Motherboard: Intel DH55TC
Please help me
The i3-540 CPU in the Intel DH55TC only supports up to 4 GB modules. 8 GB modules are not supported.
Some compatible Transcend 4 GB modules are -
TS512MLK64V3N <- DDR3-1333
TS512MLK64V3NL <- DDR3-1333
TS512MLK64V6N <- DDR3-1600 (BIOS will down clock automatically to 1333)
By the way, can i use two 4GB ram as i have four slots in my pc???..... brispuss???
Yes, two 4 GB modules can be used. But keep in mind that two individual modules might not work together because of variances in module characteristics. This applies even to modules with the same part number. So it might require trying several modules to find the memory combination that is compatible with each other.
Ok, thank you so much
