Transcend aXeRam 2400-MHz for Sabertooth p67???
Ever simply try to OC your Sniper's??
Raise the:
DRAM Voltage 1.50v -> 1.60v ; there are several versions of Snipers 2x4GB 1.25~1.50v
DRAM Frequency -> DDR3-1866 or DDR3-2133
DRAM Timings / Manually set the (CAS-TRCD-TRP-TRAS-CMD)
Rather than reinventing the wheel, see -> http://www.tomshardware.com/reviews/corsair-vengeance-crucial-ballistix-kingston-hyperX,2907-7.html
Set ----------------------------------------- | DDR3-1600 | DDR3-1866 | DDR3-2133
Geil Evo Two GET38GB2200C9ADC ------------ | 9-11-9-12 | 8-9-8-10 | 7-8-7-8
G.Skill Ripjaws X F3-12800CL7D-8GBXH ------- | 9-11-9-13 | 8-9-8-12 | 7-8-7-10
PQI Immortality Turbo MFAFR602SA7001 ------ | 10-11-10-11 | 9-10-9-10 | 7-9-7-9
Patriot Viper Xtreme PXD38G1866ELK...
Interesting RAM, but nothing I'd recommend. If you're gaming then DDR3-1600 2x4GB CAS 8 e.g. F3-12800CL8D-8GBXM http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
Gambling serious stability concerns for 0.5~1FPS seems crazy to me. Also, 8GB will add more FPS over ANY 4GB kit. Also, on the Sandy Bridge DRAM Voltage of 1.50v is a better choice.
The ONLY viable argument is for obscure uses (odd Multi-tasking) and bench tests, I can make the similar arguments for DDR3-1333 CAS 8.
ref - http://www.bit-tech.net/hardware/memory/2011/01/11/the-best-memory-for-sandy-bridge/6
ref - http://www.tomshardware.com/reviews/ram-memory-upgrade,2778-8.html
well, I don't do any gaming at all, but i was just looking into a high performance ram kit mainly for performance test, because i already have 8gb of g.skill sniper's... sooo, ya i was just wondering if it was a good buy, because i herd that cas latency does not really matter with SB??? is that true?
Raise the:
Patriot Viper Xtreme PXD38G1866ELK --------- | 10-11-10-11 | 9-10-9-10 | 8-9-8-9
Kingston HyperX T1 KHX1600C9D3T1K2/8GX -- | 10-11-10-12 | 8-9-8-10 | 7-8-7-8
Crucial Ballistix BL2KIT51264FN2001 ---------- | 10-12-10-12 | 9-10-9-10 | 7-9-7-10
Corsair Vengeance CMZ8GX3M2A1600C9 ------ | Unstable | 9-10-9-10 | 7-9-7-10
PNY Optima MD8192KD3-1333 ----------------| Incapable | Incapable | 10-8-8-24
Then remember the - Real Speeds Frequency & CAS:
TX2400KLU-4GK DDR3-2400 10-12-11-28 at 1.65V
