Just as the title says, I have located a leak at the point where the transmission line connects to the radiator. It only leaks while the engine is running (or shortly after it is turned off) so im assuming is pressure based. Its not spewing about like a hose, but it does seem to have a steady drip. I refilled my transmission fluid to the appropriate level, and added the same appropriate level of BlueDevil transmission sealant (as it seemed to be the highest rated one I could find during my research).
The bottle states that it takes up to 100 miles to fully do its job, but I was wondering if this will seal the coolant line leak. Some sources says it does, and others say it doesn't.
And if it doesn't, would radiator coolant leak repair work? Or is that of its own piping?
