Tri sli 470 gtx power requirement
therevaj
13
Debating going tri sli GTX 470s on a z77a-gd65.
Have a 3570k stable @ 4.4 ghz on 1.25 volt.
Would debate ocing the 470s to 750-800hz @ 1.087
Currently have seasonic x-850. Would that be enough to run my rig?
Thanks for the replies!
When using an Ivy Bridge Processor the three PCIe 3.0 x16 slots of the MSI Z77A-GD65 have the following possible support options:
x16/x0/x0
x8/x8/x0
x8/x4/x4
That means that 2-way SLI is the maximum supported. For the graphics card to be included in the SLI set the x16 slot must have a minimum of 8 PCIe lanes and only two of the three x16 slots on that motherboard have at least 8 PCIe lanes or more.
Your talking close to 800W when your system is in load. Personally I wouldn't push your PSU to that limit and if you OC your components you will probably be hitting pass 850.
If it were me I wouldn't.
What would be the consequences of doing so.
Aka, what are the worst things that could happen?
x16/x0/x0
x8/x8/x0
x8/x4/x4
3-way or 4-way SLI with an Intel Z77 Express chipset motherboard requires that the motherboard also have the PLX PEX8747 bridge chip.
Examples:
ASRock Z77 Extreme9
ASUS MAXIMUS V EXTREME
ASUS P8Z77-V PREMIUM
ASUS P8Z77 WS
ECS Z77H2-AX
EVGA Z77 FTW
Gigabyte G1.Sniper 3
Gigabyte GA-Z77X-UP7
Wow, so way above what I was considering.
Thanks for the help!
