Question Trident Z 32gb 3000mhz and x470-f MoBo
DatBoi69
Commendable
Dec 28, 2016
20
My pc isnt liking my new upgrade. I went from having two sticks of 8GB ballistix sport Ram at 2400mhz to two sticks of 16GB Trident Z ram at 3000mhz. The very first thing I noticed is that it didnt want to post. I turned it off and the power supply turned it all back on and it worked fine. I didn't play any games but was just surfing the web and YouTube. Worked fine. But as soon as I try to load up any game it would immediately crash the game, or wood crash whenever it is at a high load. GTA has presets set at ultra or highest at 1080p. After I boot into the game thirty seconds later it crashes. It freezes up and doesn't let me do anything and the keyboard and mouse lights turn off. the PC still runs and the screen is still displaying... but, I'm not able to do anything. As soon as I take out one stick of ram it goes back to working perfectly fine. I know the motherboard can support 64 gigs, so does it simply not like the ram? Do I need to do a bios update? Wtf?
Crosslhs82x2
Respectable
Aug 12, 2017
542
44
2,090
33
Listing all specs will get things going first to get more help.
Try resetting cmos by booting to bios
Load optimized defaults
Or unplug power from psu
Press and HOLD power button for 15 secs.
Install 2nd stick
Reboot to bios
Then set docp and 3000 dram frequency.
Any other changes like xfr / pbo can be done later.
Please post back with results.
Reactions: DMAN999
Update to latest BIOS if possible.
If both modules work fine individually, they should be able to work fine together.
Also, you don't want the free floating memory module there when powering ON the system, especially if it's touching metal to metal..
