Tradesman1 :
What set of Corsair - if stock they run 9-9-9-24 1.5 would prob want to try the DRAM at 2133 12-11-11-30 1.65 and also want to raise the CPU/NB voltage to about 1.25 or 1.3
my default xmp is 9-9-9-24 1.5v
i have succeed raise my 1600 into 2133 Mhz with 10-11-10-31 @1.600v but not long after i running test with browsing internet my windows is hang, then I find my self my test is not stable.
well then..., I guest I have to try your suggestion
thanks.
I'll let you know if it work or not.
I have tried your timing setting as you mentioned, and this is the result :
https://postimg.org/image/jqp3jycan/
and i have tested my own setting which is 10-11-11-31 1.600v and this is the result :
https://postimg.org/image/ifuhthdcp/
which one do you thing is the best ??
