Triple 1080p monitor mini ITX build
onikage34
Looking for some opinions before I finalize everything and purchase the parts.
http://pcpartpicker.com/list/mbVF4C
Planning to have 240mm radiator+4 fans mounted on the front(Push/Pull) and 2 120mm fans on the top for the air flow configuration.
Will be a triple 1080p monitor rig.
Anything I should take out/replace/add?
1. corsair ML series, you can set the fans RPM in easy tune later. Add PWM hub, connect to the CPU fan header.
2. SC is 267 mm in length + p/p 100i is 80 mm thick = 348 mm, air 240 is 320 mm in depth.
3. Typical p/p is around 50 to 100c for every 10c coolant temperature rise. Push only @ 80% RPM will keep 6600k under 70c which is suffice for 200 Watt TDP.
4. I use https://www.ekwb.com/shop/ek-xlc-predator-240 (top mount) CPU GPU loop. Cooled VGA with https://www.ekwb.com/shop/ek-fc1080-gtx-tf6-nickel, add https://www.ekwb.com/shop/ek-coolstream-se-240-slim-dual (push out to front) and https://www.ekwb.com/shop/ek-hd-tube-10-12mm-500mm-2-pcs + https://www.ekwb.com/shop/ek-hdc-fitting-12mm-g1-4-nickel. I do heavy after effect rendering...
4. I use https://www.ekwb.com/shop/ek-xlc-predator-240 (top mount) CPU GPU loop. Cooled VGA with https://www.ekwb.com/shop/ek-fc1080-gtx-tf6-nickel, add https://www.ekwb.com/shop/ek-coolstream-se-240-slim-dual (push out to front) and https://www.ekwb.com/shop/ek-hd-tube-10-12mm-500mm-2-pcs + https://www.ekwb.com/shop/ek-hdc-fitting-12mm-g1-4-nickel. I do heavy after effect rendering and encoding, stock cooler is too noisy and finish the render longer.
If those are gaming build, consider slim 15 mm fans such as Thermaltake Luna 120 slim for 100i bottom mounted, for tidiness get full modular power supply and something like https://www.amazon.com/Nanoxia-CoolForce-Anodized-Aluminum-Organizer/dp/B01DNMYL5Q/ref=sr_1_2?s=pc&ie=UTF8&qid=1477012278&sr=8-2&keywords=Nanoxia+CoolForce+Anodized+CNC+Aluminum+Cable+Clip+Organizer
