Question Triple 4k connectivity on 3050 - help please
4
Hi,
I'm hoping someone can help with this - firstly 3d performance is not an issue, this set-up is solely for desktop 2d photo editing in Windows.
Can you connect 3x 4k monitors to a 3050 via DP, specifically an "EVGA GeForce RTX 3050 XC GAMING 8GB ". It has the required connections, 3 DP 1.4a (and 1 HMDI 2.1)?
The specs state that the maximum digital resolution is "7680x4320 " which is 8K, but I am unclear whether this applies across all DP outputs or just one (Triple 4k is 11520 x 2160)
Thanks in advance for the help
Bats
I got a reply from EVGA support
"Hello,
Thank you for contacting EVGA Support.
The Graphics card can support Maximum Digital Resolution = 7680x4320
means you can connect two 4k displays with 3840 x 2160 Resolution.
Please do not hesitate to contact us if you have any further questions.
Kind Regards
EVGA Support Team"
So that's a "no"
Has anyone on the forums managed to connect 3x 4k screens to a 30 series card (they all state 7680x4320 limitation)?
{Update] I have just asked Nvidia and they have told me it is possible -
"Nvidia: Connecting 3 4K monitors for RTX 30 series GPU is supported
Me Thank you, they will all run at 3840x2160 resolution?
Me: via DP connections
Nvidia: Yes "
But it would be nice to have confirmation from any forumites ~ :)
