Triple Monitor Gaming Pc Build Help Needed
Siccmade
11
Looking to build a gaming rig with 3 monitor setup and wondering what best parts and best way to go with this would be. Hoping to be $1500-$2000 with monitors and nvidia is graphics & asus board. Just not sure where to start with this and little more or less $$ is fine, just need some start info thx
I was facing a similar dilemma not more than a month ago. Did i really want to upgrade to three 144hz monitors? Even if you don't play games, the native 144 hz is very smooth for everyday use. It makes for a very pleasurable windows experience. If you have the money, then a 144hz will provide you with a good experience either way.
A 144hz monitor technically will be more "stress" on the pc because the GPU has to work more than twice as hard as with a typical 60hz monitor of the same resolution.
What do you want more? more monitors or a higher native refresh rate?
If you want both, you will need to drop more $$$ on GPU's to get a gaming experience to take advantage of the 144hz.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.75 @ OutletPC)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($129.99 @ Amazon)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory ($79.99 @ Newegg)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive ($59.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($77.75 @ OutletPC)
Video Card: Zotac GeForce GTX 970 4GB Video Card (2-Way SLI) ($329.99 @ Newegg)
Video Card: Zotac GeForce GTX 970 4GB Video Card (2-Way SLI) ($325.99 @ SuperBiiz)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: Corsair 850W 80+ Gold Certified Semi-Modular ATX Power Supply ($99.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($14.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($89.98 @ OutletPC)
Total: $1521.38
Generated by PCPartPicker 2015-01-07 22:44 EST-0500
So why not an I7 instead of I5? and i seen some asus boards ( ROG) that look really cool with the red on them? are those higher end boards? From videos i seen alot of newer rigs have those
ok and how about this setup.....Graphics - EVGA GTX 970SC 4GB ACX2 Graphics card
Motherboard - Asus Maximus VII Hero ATX ROG
Processor - Intel Core i7-4790K
Cooling - Corsair H110i CPU Watercooler, self contained no upkeep needed!
Memory - Corsair 16GB 2x8 1866mhz running in dual channel
Storage - Crucial 256 GB MX100 SSD
Power supply - Corsair CS750M 80+ Gold rated PSU, Modular
Case - NZXT H440 White ATX Tower
Found this near by me and wondering ppl thoughts
well the package does come with a asus 144hz monitor.....would have to get few more to complete my pc but want the best card or cards so the 970 wont work as good as the 780?
What games will you be playing? For an example, I get less than 40fps on Crysis 3 in 5760x1080, high settings. I have the Gigabyte GHZ edition in SLI and overclocked a bit more...
for some 970 sli benchmarks...
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_970_SLI/6.html
If you truly want to game with 144hz in surround, you need to:
a) play slightly older games
b) get super high end GPU's
c) turn settings down to get over 60fps, otherwise the 144hz is a waste.
