Triple Monitor Help??
Pranaysonu
24
Hello Guys!!
I just Want To ask a question!!!
It's That about Nvidia Surrounding(3 Way(Triple Monitor)) Using an Nvidia GPU!!!
My Specs,
CPU :-AMD FX 8350(4.1 GHZ Can OC Upto 4.5 GHZ).
GPU :-Asus GTX 660TI(2 way SLI)
RAM :- 4GB DDR3@1300MHZ :/
Motherboard :- MSI 970A-G46
PSU :- Corsair 1200W!!!
My Question Is Can I add three display(i.e, Triple Monitor) in these Specs????
My Monitor :-
LG 19 inch(1360 x 768)!!
I want To add three monitor of the same 19 inch!
Is It Possible???
And If Yes Then Plz Tell me in detail!!!!
Explain In Detail!!
Thank You!!!
when you say add 3 monitors do you mean add 2 and have a total of 3 or add 3 and have a total of 4. and I recommend getting another 4gb of ram so you can have 8, or dump the 4 an dget just 1 kit of 8 so in the future you can hold 16gb.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161432
^My GPU- its 4gb, but does not have a 4gb Price, and hold 3 27" Monitors all at 1080p
But, I dont think you need a new GPU, yours is fine, especially in SLY, Yes you can do it, just google a tutorial, I usually think 1GB=1 Monitor, so 4GB and 3 monitors Would Work, and As the guy said above, RAM. You dont need the ram to get the 3 monitors, but that is a HUGE bottle neck in your build, and 4gb would barely Cut 3 monitors, But your FPS will drop
