triple monitor help
Andrew Mendonca
23
Okay so today i bought a cheap monitor too have a 3rd display but i cant seem to figure how out to get it to display something i have 2 connection to my gpu and one connected to my mother bored monitor one ( main) connected via hdmi monitor 2 secondary and its connected via dvi
and the new one connected via vga becuase i dont have any spare dvi cables Any help would be great Thanks!!
If I understand you correctly, you're trying to use both your integrated graphics chip and your add-on GPU card at the same time?
That won't work because the the integrated graphics chip is automatically disabled when you install an add-on graphics card, this is necessary to prevent a resource conflict between two similar devices which perform the same task.
That is, unless your BIOS has a setting which allows you to use both GPUs at the same time, a feature found only on certain motherboard models.
my APU and GPU are running in crossfire right now i i had the 2monitors on separate things before i moved into my new room and since then iv just ran them both on the gpu but now that my gpu is full i am going to try to run the 3rd monitor on the mother bored also the mother bored i have is MSI Socket FM2/AMD A85/DDR3/SATA3&USB3.0/A&GbE/ATX Motherboard FM2-A85XA-G65
