Question Triple Monitor Help!
Oct 24, 2020
5
I have 3 units of Lenovo L24i-10 monitors. What I'm trying to do is get them to work on a triple monitor setup but I can't make it work. My graphics card is 1050Ti 4gb DDR5. Dual monitor connection is working, HDMI(gpu) to HDMI(monitor) and DVI(gpu) to HDMI(monitor). But the problem is that I can't get the 3rd monitor to work using a Display Port(gpu) to HDMI(monitor). I already tested 4 or 5 DP/HDMI cables and adapters but none of it worked. Please help.
SteveRX4
Notable
BANNED
Sep 29, 2020
1,477
136
890
293
A 1050Ti is a bit light on to run 3 1080p monitors.
It look like all your displays have one HDMI and one VGA connector.
Does your GPU have one DVI, one HDMI and one DVI?
Oct 24, 2020
5
Yes, as I explained all of the monitors have 1 HDMI and 1 VGA. and the GPU has 3 connectors, 1 HDMI, 1 DVi and 1 Display Port.
Oct 24, 2020
5
Are you certain the card even supports three displays at once? Normally, you'd find "NVidia Surround" in the specs page, but I'm not seeing it.
-Wolf sends
Yeah Nvidia surround is supported by 1050Ti, there's even youtube videos that show how it's done by users. But unfortunately for me, I can't make it work.
