triple monitor mount suggestions?
Mar 13, 2018
11
I am looking to get a Triple monitor mount for my setup, currently have a 24 inch middle display and two 23 inch side monitors (Dell Gaming Monitor S2417DG and 2 Acer h236hl).
Im wondering what would be the best mount for the job that isnt going to break the bank. Preferably under 80$ and I want it to be sturdy so I dont have to worry about it collapsing or anything like that.
Thank you
Two other options (much cheaper) and I have a bunch of these at the office I work at (but the Dual mounts not tripple)
https://www.amazon.com/Mount-MI-753-Computer-Monitors-Compatible/dp/B00BDT072S/
OR
https://www.amazon.com/Mount-Freestanding-Compatible-MI-2789-Horizontal-x/dp/B01HSJX1FG/
(just depends if you want feet or mount it to the desk all under your $80 price range (if you are in the us) it will then fit all 3 of your displays :) I had to get the more expensive one partly because of my unique setup.. yours is a bit more standard :)
well more then $80.. but the one I use is https://www.amazon.com/gp/product/B07741G5P2
I used to use an cheaper triple monitor setup without moving arms.. finally moved to this one.. its SO NICE..
Plus I upgraded when my old monitors (1080P 24in ones started failing) now I have 1 28in ultrawide, an 28in 4K, and one old 1080p 24in that still works good on that monitor stand.. I tried it on my old non movable and it was just WAY too painful plus the ultrawide would not fit when I had to get that one when the second old monitor died.
Thats nice but I think thats too much out of my range, unless it goes on sale during black friday weekend I dont think I can do that one
OR
Do you think mounting it makes it more sturdy or do you not really notice a difference?
