Triple monitor not working
Yiannis_2
4
Hello guys! I have problems setting up my third monitor.. I have amd radeon hd 7700 graphics card and have already connected one screen(my main one) on the dvi port and my television on the hdmi port and try to connect the third one to the vga port of my motherboard with no results.Anyone can help?
Finally worked! The problem with the AMD cards is that you have to fullfill the graphics card ports before using anything else,so i bought the DP to VGA adapter and worked perfectly :)
First of all thanks for your time :)
Well i have my main screen connected with a DVI adapter(VGA to DVI) and a TV with hdmi both on the graphics card for a long time with no problem. But for the triple screen setup, i saw a post (can't remember where) in which the guy had all ports of the card used,surely by using adapters.
So,i have to find a DP to VGA adapter to use all my graphics card ports and have the triple screen??
