I just got this VisionTek card model #900530 with only 500MB. It is an older card from 2012 and the manufacturer has removed the specs from their website. Card comes with two dual link DVI-I ports and mini-displayport. I eventually would like to run 3 monitors (2 DVI - 1 DP) all at 2560x1440 resolutions. I have read that either AMD or VisionTek chokes the second DVI port to single link DVI. Further, if one of your DVI monitors is 2560x1440 then the 2nd DVI will be limited to 1280x1024. Can anyone confirm this?
Running the DP monitor at 2560x1440 should be no problem provided monitor has a DP connector. Just not sure about the maximum rez specs when also using two DVI monitors?
