Tripped Circuit Breaker| Help
iNizie
33
I just built my gaming pc about 2 weeks ago and i have it plugged into a power strip along with my monitor. Every once and a while the circuit breaker for my room will trip. Unlike a lot of other posts I have read, my computer still works perfectly fine once i turn it back on. Could it be a problem with the PSU taking to much power in? I watched a video and with my specs I would only be using like 300w or something on load. I am afraid of playing games because of this- I dont want to mess up my brand new computer
These are my specs if it matters
i5-4670k (not overclocked)
gtx 760
8gb ram
PSU: (this is all of the info about it on newegg)
EVGA SuperNOVA NEX 750 B 80 PLUS BRONZE Certified 750W Active PFC ATX12V v2.31/EPS 12V v2.91 5 Year Warranty 120-PB-0750-KR SLI Ready CrossFire Ready Modular NEW 4th Gen CPU Certified Intel 4th Gen CPU Ready Power Supply
I got a 750w psu because i will be upgrading components in time.
Are you in a house or an apartment? I've had apartments with some pretty dumb circuit arrangements. Your computer wouldn't be pulling enough to trip a breaker by itself, odds are you are sharing the breaker with another large power draw. Anyone else live with you? Did someone turn on a hair dryer or start trying to make popcorn at the same time? Microwaves and hair driers are massive power draws but they are used so little we tend not to think of them.
Ok ill check
it is a surge protector
this is what it says on it.I don't know if it matters though
Electrical Rating:120VAC, 15A,60Hz,1800w
Voltage Protection Rating: L-N 400V,L-G 400V, N-G 400V, TYPE 3 SPD
Okay, just making sure.
I live in a house with my mom and brother. When it trips it is only my room only the switch in the breaker box thing for my room turns red and only my room.
No they weren't doing any thing... my mom was watching tv and my brother was eating lunch and on his phone when it happened the 2nd time.
Nope just every thing in my room, all of the other rooms stay fine. My TV, fan/light, PC, monitor, alarm clock and everything else that is plugged in turn of
Uhhh no, normal apartments only have a 100A main breaker, your individual circuit breakers are generally 10, 15, or 20A. You will only see breakers >20A for special purposes like dries, stoves, water heaters, etc.
Is the breaker for your room an Arc Fault Circuit Interrupter (AFCI) type circuit breaker?
Is the breaker tripped when the system is turned on or during normal use?
You can get false positive tripping during system turn on due to the large inrush current that happens when the primary capacitor(s) in the PSU are being initially charged.
on the actual switch it says 15 and next to it it says 10Ka
it doesn't trip when i turn it on
And yes i believe it is an AFCI ( i have no clue what that is it but it said something about it on the panel
Swapping out a breaker that is tripping for a higher current breaker without knowing WHY it is tripping is actually a very dangerous idea. Breakers are safety devices, they are meant to limit the current so that the wiring in your house won't burst into flames. Unless you have wiring rated for the current limit of the breaker you shouldn't upgrade the breaker, and you should also seek out the source of the tripping breaker. If you have really old looking breakers they can fail over time and become more prone to tripping prematurely. I would see about replacing it with one from the same brand with the same current rating, or consult an electrician and have him make sure that the house's wiring is up to snuff.
If it is tripping with the computer on that is weird as the current draw will have pretty well stabilized so unless its a matter of drawing more than the breaker will tolerate for a long time there is likely a culprit outside of the computer. One day when you won't be home but others will be just turn off the breaker that turns your computer off, see if anyone in the house notices something isn't working, thats the easiest way to see if there is something common that is on the same circuit as you!
AFCI is arc fault current interrupter, it is designed to trip for sudden spikes in current which indicate an arc has occurred. These are fine for normal applications, but you can make them trip unintentionally depending on the application and load. You get an arc every time you flip a light switch, start a furnace, and you get seeming spark every time something with a big power supply or motor starts up as they have a sudden and massive inrush current. Though when the computer is running it shouldn't be tripping an AFCI as it will have a fairly continuous current draw.
Running on breakers that are too high for the wiring is a very risky game as breakers don't actually trip at the rating they say, they just won't trip below that. To trip a Square D QO breaker in a second or less you will need to exceed 6x the rated current draw, which means for a 30A breaker you will have 180A running through your wires for a full second, which is more than enough to cause 14 gauge wiring to burst into flames, 14 gauge wiring will blow open if you run 166A through it for 10 seconds so you are going to have a lot of melted copper before that breaker trips.
http://www.grainger.com/ec/pdf/QO-QOB-Miniature-Breakers-Catalog-2008.pdf
A 15A breaker can provide 1800W of power and is the maximum advised for 14 gauge wiring, 12 gauge wiring can be hooked up to a 20A breaker which will provide 2400W of power. For a computer and monitor that is pulling 500W max, 1600W should be more than enough. (These wattage numbers are for 120V, european systems have similar current ratings on wires but will get about twice the available power for the current rating)
Yeah, your computer and TV shouldn't trip the breaker, but there might be other devices running on this circuit that you don't know about. Like hunter315 said, switch off the breaker and look around the house to see if anything else isn't getting power.
Arc-Fault Circuit Interrupters are prone to “nuisance tripping”.
AFCIs are designed to sense an arc, which is an electrical “leak” caused when a hot wire touches a neutral or ground that wouldn’t necessarily trigger a conventional circuit breaker.
Current-sensing circuitry enables AFCIs to detect arcing conditions. Unintended trickles of current may also cause the breaker to shut off (i.e. AFCIs are very sensitive!).
Surge protectors shunt voltage spikes to ground and that can trip the AFCI breaker.
Any electrical/electronic device that allows current “leakage” can trip the AFCI.
