Janetdax :
harrysmellington :
Where did you get that copy of windows 10? Also can you post the location of the trojan.
I used the media tool from Microsoft to clean install windows 10 from a usb drive, Originally this system was a free upgrade from Win 7. Vipre doesn't provide a location of the problem. However, I did notice it was scanning C: Users at the time. My system consists of 2 SSD's and one HD
C for the OS, D games, and E for storage and swap file. Only the C drive is infected.
Then you didn't do an actual clean reinstall.
This would indicate it is something held over in your Users folder, and when you did the reinstall, you selected "Keep everything"
Which does exactly that...only reinstall the OS, and keeps all your applications and files where they are.
Something in there is infected.
Do an actual clean reinstall. Wipe ALL partitions ont he drive and reinstall to a blank system.
