Tron Help
user
Splendid
Dec 26, 2003
3,943
Archived from groups: rec.games.video.arcade.collecting (More info?)
I have a tron cabaret with a 13 inch monitor and when I start it up the
screen will blink different colors like white and red. If I turn it off and
on several times the game comes on. Any ideals?
Thanks
mcrue1NOJUNK@hotmail.com
"." <mcrue1nojunk@hotmail.com> wrote in
news:1117420345.636edf8a1247ed2e5e8d31238534aa70@teranews:
> the screen will blink different colors like white and red. If I turn
> it off and on several times the game comes on. Any ideals?
> Thanks
Power board
Have you checked the voltages at the boardset?
-Tom
It's 90% in the power supply. Install a switcher, you'll thank me.
- Matt
Almost sounds like it is going through the normal self test routine to me.
It could be a power supply problem. Check for sagging voltages and a good
reset signal on the board .
Mark Hooks
"." <mcrue1nojunk@hotmail.com> wrote in message
news:1117420345.636edf8a1247ed2e5e8d31238534aa70@teranews...
> Thanks
It's the power supply's RESET circuit, well known to be problematic and
exhaustively documented as relates to this problem. A quick Google search
should have turned up the answer a number of times.
Clip the RESET line (purple wire), and I'm 95% sure you'll never have that
problem again. This doesn't seem to work on all MCR games (Spy Hunter being
an example of one that you can't fix this way), but it always works on Tron.
It is still worth shotgunning the PS though. It'll cost you $10 in parts
and run for years.
Rob
> Thanks
