Trouble Building PC with Old Biostar Motherboard
sunshinefox
6
Hello I am having difficulty getting my motherboard to respond in any way after just building it. I have been building several older style computers along side this one with no problem at all (an ION board running Windows 10 which was fun), but this one baffles me to frustration.
It is a Biostar T5XE CFX-SLI ... about 7 years old I think, but it was just untouched forgotten in a box in storage.
When I power on the machine, everything comes online okay for a few moments, some of the status LEDs on the motherboard flash and then it just power back off. There is never any display on the monitor or any beeps.
All I can tell from the LEDs are that the 6 lights up by the CPU, only the right 3 will come on and then the 2 at the bottom show "VGA error" according to the diagram in the manual.
LINK TO THE MANUAL (page 20) http://manualzz.com/doc/4181046/biostar-t5-xe-owner-s-manual
I can add specific photos of it if need be, but I have tried multiple ram sticks and graphics cards all with the same result.
Any help would be awesome thanks!
old pc start with a fresh cmos battery and clear the cmos. with a good flashlight look on the mb and power supply for leaking or swollen caps. check for bugs/dust/mouse poo that may have shorted out the mb or video card. reset the video card make sure it locked in.
--UPDATE--
Got a bit sidetracked... hence the delayed response... however, on my own I managed to discover that my initial problem was apparently aggravated or partially caused by a dead/dying BIOS battery - which after replacing it, the PC was finally able to come up, post, and let me into the BIOS for the first time...
All seemed fine at first, but it is acting weird in some more specific ways now. Here is the BIOS version info in the first pic
biostar_pc_01
First off even with the brand new battery, doing a hardware clear on the CMOS (repeatedly), and something in firmware about clearing the CMOS it refuses to save certain changes. Every time it comes back up it says "bad checksum" on the boot post:
biostar_pc_02
I'll go back to the BIOS screen, re-enter things, try to reboot, and it does the same thing again. It's saving SOME data - like the date/time. But not everything I enter into the BIOS, some things reset (like I've repeatedly disabled the floppy drive since there's nothing connected to it and it always resets, other things too though I didn't keep a list, and every reboot gives the same "bad checksum")
Second, it's still not seeing the RAM. I have two 4gb each sticks - running either alone shows up as 3gb visible to the BIOS. (I thought there was some way to get around what I thought was a 32bit problem of having a hole there but that's separate) Running both together still only shows 3gb visible - no matter what slots I put it into, single or dual channel. Unless whatever is causing the memory hole between 3-4gb is also blocking it seeing the full 8gb of RAM.
Third it's acting a little funny with seeing the hard drives.
biostar_pc_03
biostar_pc_04
Basically I cannot simultaneously view a USB stick as bootable and SATA drives as bootable no matter what I do. (and disabling the floppy just means nothing) All it wants to show for options are Floppy, CD/DVD, and either recognized USB key or SATA drive. This is making it hard to install windows.
PARTS LIST
OS - nothing yet, Windows 10 Pro is what will eventually be installed
PSU - Cooler Master GX 750
CPU - Intel i3 540 with the basic heatsink fan combo that came with it.
RAM - 1 stick Crucial 4gb DD3 1600 PC3 - 12800
VIDEO - 2 EVGA GeForce GTX 260 (same issues using 1 or 2)
2 generic HDDs
1 generic DVD drive
I posted an update on my issue as well as my parts list and OS... see the longer post.
All the parts were still sealed in their bags, no oddities, however the battery did end up being the initial culprit... see the longer update post.
To install Windows from a USB key, try setting the floppy dive as 1st Boot Device and your SATA drive as 3rd Boot Device. On many older machines if the floppy dive is set as 1st Boot Device, but a floppy drive is not connected, it will boot from a USB key as well. Just disconnect your floppy drive.
Yea... I was afraid it might be that, never really flashed a bios before, was always concerned about accidentally bricking the board.
I did manage to get Windows 10 Pro installed after testing the different SATA devices one by one, and the system runs terrific once it loads.
However, the "bad checksum" still shows up every single time it boots... and Windows will show 4gb total ram but only 3gb usuable "hardware reserved"... but if the the CMOS chip is bad like you say, then that would explain why none of the bios settings stay saved and just reset every time.
