Hi,
I'm hoping someone can help me with setting up dual monitors.
I'm currently running my graphics from my graphics card via a VGA cable [I have a Asus Radeon RX 550 4GB Graphics Card, it only has one VGA slot, does not have a DVI slot].
When I plug in the VGA and/or the DVI cables into my motherboard, it doesn't work. (I have a Asrock AB350M-HDV Motherboard, in the manual it says it has triple monitor support).
If I plug one monitor into the motherboard and the other into the graphics card, the second monitor will say "No Signal". If I plug both into the motherboard, both monitors say "No Signal".
I've gone into the ASROCK UEFI BIOS to try and change the graphics settings. Most forums have suggested to go to Advanced > North Bridge Configuration and graphics settings will be there, however the only thing listed in there is 'IOMMU support' and nothing else.
In the Advanced > AMD PBS, there is an option for "Primary Video Adaptor" however that option is greyed out, and I can't click on it at all. The option there says: Ext Graphics (PEG)
It's not an issue with my monitors as far as I know, as I've plugged both into the graphics card separately and they work fine. I have two ACER V243HL's.
I'm unsure what is going wrong? Hopefully I've supplied enough information and it's easy to follow & understand.
Thank you so much!
Thank you so much!
