Question Trouble with case fans
Jul 16, 2022
4
I am building my first PC with my BF and the case came with fans, but we can not figure out how to get them to work, the case Is the NOVA Mesh SE TG Midi tower, Nova Mesh SE TG 4ARGB White - BitFenix Shop , The MB I'm using is the MSI B450 Gaming Plus Max B450 GAMING PLUS MAX | Motherboard | MSI Global , it has a port for pump fan Cpu fan and 4 for system fans. I've tried going into the BIOS and changing around the settings and taking the main cord that would power the fans into each port but nothing I have tired is working and I can't find anything online, none of the fans in the case have worked for me yet, I have a CPU cooling system that is plugging into the CPU fan port. Any advice?
Go here: https://www.bitfenix.com/products/chassis/atx/nova-mesh-se-tg/ click on "How to connect RGB/ARGB" (it's at the top of the page), it either opens up or downloads the *.pdf manual, on how to set up Bitfenix ARGB fans. Read it and you should be golden.
Btw, that MoBo doesn't have 3-pin +5V ARGB header, so skip the page 6 on Bitfenix ARGB manual. Instead, look at page 3 on how to control the ARGB fans instead.
  • You need to use PC case reset switch and connect it to "SW" labeled pins, on the 6+6 hub, to control the LEDs.
  • Or when your PC case has dedicated switch for LEDs, connect that switch cable to "SW" pins instead.
Reactions: madigardn
Thank you, I tried following that but the second connection for the mother board the wire only has space fore three pins and all the connections on my MB have four pins
Got it working! Idk what my bf he read that Manual you sent the link too and they started to work! Thank you for the help!
Reactions: Aeacus
