Question Trouble with connections with led fans.Reset Sw+/Power Sw+/H.D.D Led+/Power LED on the H110-I/G11CD/DP_MB ?
What is the make and model of your motherboard? That PSU looks very sketchy, on second thoughts, please pass on the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
Hello!! Thanks!
This is what i was able to get. Its a prebuilt pc that I got so not much info or manual for the motherboard or really anything. I recently bought a new chassis gamdias aura gc2 and just having problems with turning it on.
CPU TypeIntel Core i5 7th Gen
CPU NameIntel Core i5-7400
L3 Cache Per CPU6 MB
CPU Main Features64 bit Quad-Core
Motherboard:
ChipsetIntel H110
Thats all i could find on the motherboard info
Ram: DDR4 12G
SSD/HDD: HDD1TB
GPU:NVIDIAGeForceGTX 1050 2GB
PSU: 300w it came with the pc. Since its prebuilt. Had it for a while now 6 years
Chassis: Gamdias Aura GC2
OS: windows
Hello!! Thanks!
Motherboard:
ChipsetIntel H110
Ram: DDR4 12G
SSD/HDD: HDD1TB
OS: windows
This is the manual for that motherboard:
https://dlcdnets.asus.com/pub/ASUS/...in_Definition_v2_web_only.pdf?model=H110-PLUS
On page 1-10 you will see the pinout diagram for the 20-8 pin panel that you show in your picture.
Thanks! I did all of that and still wouldn’t turn on and today i tried it and it turned on but only 1 fan was working but now it wont turn on again… i got a new power supply 600w ( instead of the 300) could it be the motherboard or the new chassis led connections?
Is the connector for the power button labelled + plus and - minus? Did you try reversing the connector on the pins?
