Trouble with Internet Connection Sharing (ICS) from PC to Xbox 360 through Patch and Crossover Ethernet Cables
JamesAllen
107
I am attempting to set up Internet Connection Sharing (ICS) from my desktop PC to my 360. My current setup follows:
[urlExt=http://www.amazon.com/gp/product/B00AWRUICG/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1]TP-LINK TL-PA4010KIT AV500 Nano Powerline Adapter[/urlExt] --> Cat 5e patch --> PC motherboard Ethernet input --> [urlExt=]TP-LINK TG-3468 PCIe Network Adapter[/urlExt] --> Cat 5e crossover --> Xbox 360
(note: while this diagram refers to xlink: kai, this thread is only a question about ICS and not the program itself)
I have set my network connection that goes from the Powerline Adapter into the motherboard input as shared (using directions from multiple sources on how to enable ICS). I have included a screen grab for reference.
However, my Xbox 360 still cannot connect to Xbox Live (note: Xbox Live is NOT down, the 360 simply cannot connect to the internet through the shared connection).
Anyone have an idea of what is going wrong?
OK. In that case you just need the $10 switch rather than the $7 NIC card... Put the switch at the end of the...
After restoring the Xbox 360 network connection to default settings to allow it to automatically obtain a new IP address as well as restarting both my Xbox 360 and PC, I was able to establish an internet connection on my Xbox 360.
kanewolf, can I ask why you said this method is less safe? It was extremely cheap for me to buy the network card (~$7) and I already had everything else, so I thought this would be the easiest solution for me to set up Xlink: Kai. It also allowed me to skip some of the configuring that a router would have required to run Xlink: Kai.
It is less safe because you are exposing your PC (probably with windows) directly to the internet. Windows is the most attacked OS an you don't have a router with NAT and a firewall protecting it.
Yes, doing it with network hardware will cost more, router $15 and switch$10. But your PC doesn't even have to be powered on to use your console(s) and you get WIFI for phones etc.
I see what you meant. I am actually running it through a router to begin with. The complete setup should have been specified as modem > router > powerline in > powerline out > PC in > PC out > Xbox 360
OK. In that case you just need the $10 switch rather than the $7 NIC card... Put the switch at the end of the powerline link and connect your PC and console to the switch. If you want to splurge -- get a gigabit capable switch for $10 more...
