Trouble with PC fan turning on when PC is shut down
David7310
I have a Lenovo x315 FX
AMD FX-Series FX-770K (3.50GHz)
• 8 GB DDR3 1 TB HDD 128 GB SSD
• Windows 8.1 64-Bit
• AMD Radeon R9 360 2GB
For some reason when I shutdown the PC the fan will kick on at a high rpm at some random time? The monitor will still show that the PC is not giving a signal but the LEDs are light up on the PC and the fan is running high. Any suggestions? Thanks
David
To be honest here, this is kinda hard to check without trying a new component, it's kinda hard to tell you to either buy a new Mobo or buy a new PSU, I've seen this problem before and it can be either.
