J Jakester7211 Reputable Jan 20, 2016 1 0 4,510 Jan 20, 2016 #1 I have a Xbox 360 hooked up to a projector using a hdmi cable. There are no build in speakers on the projector. How would I get sound. I have tried using external speakers plugged in through the projector audio out but no luck
Solution A A americanaudiophile Jan 22, 2016 You can use an HDMI audio extractor to provide an audio output. http://www.monoprice.com/Product?p_id=5557&kpid=105557&gclid=CPPY2sLnwcYCFYIXHwodhY0FTw This will be a fixed level output so you will control the volume with what ever you use for sound.
D DiegoD Honorable May 12, 2015 288 0 10,860 Jan 21, 2016 #2 Which version of the xbox 360 do you have? Upvote 0 Downvote
A americanaudiophile Titan Aug 27, 2008 13,663 0 101,360 Jan 22, 2016 Solution #3 You can use an HDMI audio extractor to provide an audio output. http://www.monoprice.com/Product?p_id=5557&kpid=105557&gclid=CPPY2sLnwcYCFYIXHwodhY0FTw This will be a fixed level output so you will control the volume with what ever you use for sound. Upvote 0 Downvote Solution
