My parts are gigabyte b650m aorus elite 1.1, 7800x3d, g skill Trident 6400 cl32 RAM 2x16, ASRock 7900xtx, tier A PSU 850w.
First power didn't get into BIOS. Used 1 stick of RAM and got into BIOS, this worked with both sticks one at a time. Since then I installed windows, graphics driver, CMOS reset, BIOS update and made sure timings on RAM were correct. Still won't boot with 2 sticks.
Now however 1 stick in slot 4 will boot it normal, the other stick will not and when I put the other back in that slot it says there was a previous boot failure. I put the "good stick" into slot 2 and no BIOS, mobo lights indicate a VGA problem however. The other stick will not post in slot 2 either now. So current situation is 1 stick in slot 4 will start normal, same stick in slot 2 gives a VGA error. Stick 2 will not post in the first use slots. Is this enough to say bad RAM or is there more trouble shooting to do? Unfortunately I don't have another build to swap parts
