Hey Folks, I've always had good luck with getting help in this forum so here goes..
I have the following system which has been up and running for about 4 months:
Athlon64 3400 CPU
MSI K8N Neo Platinum Board
1 Gig PC3200 CL3 Kingston Ram
2 x 80gig SATA stripe
System went down yesterday and not sure where to start troubleshooting in order. System shut off while running and now dies shortly after turning on. Basically after powering up, I get nothing on the monitor, and doesn't seem to be posting at all. After about 10 seconds it powers off. I do have one of those D Bracket 4 light red/green cards and it shows all 4 red right when powering up. I've disassembled the system and reassembled to make sure there are no lose wires/screws etc.
My question is where do y'all think I should start for troubleshooting. Unfortunately I don't have another system to easily swap out parts so newbish me thinks the problem is CPU.. MBoard... Power Supply... or Memory. Any of you have any suggestions on what items to start with or anything else I can try? BTW i swapped out a hard drive and that is not the problem.
It should not be a cooling issue as I'm loaded up with fans but ya never know i guess.
Thanks in advance for any suggestions.
Athlon64 3400 CPU
