I had NO idea it would be this hard... and im going to provide as much info as possible here.
I run a 2 monitor set up at my desk. 2 x 4k displays. The main one is a C4 OLED 48in. It runs 4k 144hz HDR at 12 bit color 4:4:4 chroma. The secondary one is and old LG 4k 60hz screen, which is not important, but might come into play.
I also have a Samsung S90C in my living room. it runs 4k 144hz HDR at 10 bit color 4:4:4. I use a 35ft HDMI cable run, and its a high quality cable, and runs perfect from my computer.
My goal is to avoid having to plug / unplug that cable from my GPU when I want to switch from my main C4 monitor at my desk, to the S90c in my living room.
So i tried 3 different splitters.
https://www.amazon.com/dp/B0DGY4WBZT?ref=ppx_yo2ov_dt_b_fed_asin_title : Realized it was a 2in 1out once i got it. But... it did correctly output the 4k 144hz HDR at 10 bit i needed to the Samsung.
https://www.amazon.com/dp/B0CCHNHYDD?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 : would only do 4k 120hz, and HDR would NOT work.
So with the help of Chat GTP and a good hour of research, landed on this guy. Thought okay, just need to spend more money on something nicer:
https://www.amazon.com/dp/B0D2XGZQ2J?ref=ppx_yo2ov_dt_b_fed_asin_title : it would not even work as intended. Could not get display output to either screen. WTH?!
Finally, i had the bright idea to do what you were probably thinking at the beginning of this. Just plug all 3 screens into the back of my GPU! I did not at first, because my 9070xt GPU only has 1 HDMI out, and 3 DP out ports. Both the C4 and S90c need HDMI ports, and I was adaptor-adverse because my C4 does not play nice with HDMI-to-DP adaptors. but I tried it out anyway with the Samsung. It worked great!
But the issue is, when i want to play games on my main C4 monitor will all 3 plugged in... i get very odd stuttering, with very high frames still. I did a google, and it sounds like its "Frame Pacing".
I unplugged the Samsung from my computer so i only have the 2 monitors at my desk connected, and it goes away. My intuition says my GPU cant handle 3 4k screens, but why not?, its the latest and greatest AMD card.. and the issue still presents itself when the Samsung is off!
SO I'm back to finding a splitter that will pass through what I need it to. The Samsung screen just needs to be copied, as its in a different room and wont be used at the same time as the others. Never thought it would be this hard trying to avoid having to plug in and out an HDMI cord. Anyone who is familiar with this issue I'm having, I'm all ears on your woes and if you found a solution (other then just plug and unplug the cord)
Thank you!
Thank you!
