V valhallarising Reputable Sep 24, 2015 518 0 5,010 Dec 10, 2016 #1 im getting about 10 c cooler core temps on speedfan than in speccy and hw monitor on a intel xeon x5450 what program do i trust?
Solution synphul Dec 10, 2016 I've had pretty good luck with realtemp also. Speedfan has always been a bit wonky for me.
K KeelinTy Reputable Nov 20, 2014 929 0 5,660 Dec 10, 2016 #2 Download HWMonitor and use that to measure temps. HWmonitor is pretty close to my speedfan (about 3c) Upvote 0 Downvote
V valhallarising Reputable Sep 24, 2015 518 0 5,010 Dec 10, 2016 #3 i got hw monitor but the temps are way higher there to than in speedfan i guess i have to trust the highest Upvote 0 Downvote
synphul Champion Mar 11, 2011 9,473 7 54,965 Dec 10, 2016 Solution #5 I've had pretty good luck with realtemp also. Speedfan has always been a bit wonky for me. Upvote 0 Downvote Solution
V valhallarising Reputable Sep 24, 2015 518 0 5,010 Dec 10, 2016 #6 thanks i will try it, can the Readings be off using a lga 771 mod on 775 with modded bios? Upvote 0 Downvote
V valhallarising Reputable Sep 24, 2015 518 0 5,010 Dec 10, 2016 #7 i just tried realtemp it gives about same temps as speccy i guess i have to trus them over speedfan Upvote 0 Downvote
