[SOLVED] trust universal laptop charger buzzing noise
emirhangamer71
26
I hear a buzzing noise when I plug the charger into the laptop I unplug it from the laptop no noise its plugged in to the elecrical socket of course its trust 20194 universal adapter 90w what should I do?
Contact their support, return it, replace it with another brand/model/OEM version. Nothing really special in your case that can be done aside from the obvious. If you get a faulty product, work with the vendor to get it fixed or returned.
turns out it was loud the first time because I havent used it in a while and it was normal now its low sound it was just converting the voltage etc
