Archived from groups: rec.games.video.arcade,rec.games.video.arcade.collecting (
More info?)
hmmm....
Still confused. Maybe www.gizzoogle.com can help,
Gizoogle Translation:
"Triznon PCBs is a piece of cakes ta repair bitch. If you want ta
shotgun thizzem,
change tha 2 pizzots, tha 2n3055 pass transistor, tha shawty tantalum lytic
in
the poser of tha board, n go from there . Put ya mutha f'in choppers up if
ya feel this..
Word of advice - tha comparizzles IC in tha 5 volt line often seems like tha
problem, bit rarely is. "
nope....still confused
"Pat D" <patdanis@comcast.net> wrote in message
news:y82dnYxPlpqFFbrfRVn-2A@comcast.com...
> Ahhh, that's because Tron is French for Piece of ..... You should have
> read:
> Des Tron PCBs sont un morceau réparer le gâteau. Si vous la souhaitez
> au canon de grenaille, vous modifiez les 2 pots, le transistor de la
> course 2n3055, peu de le tantale qui est dans le milieu du panneau,
> lytisch et vous allez de là-bas. Mot du conseil - le comparateur le IS
> le 5-Volt-Linie semble, un dessus est fréquemment comme le problème rare.
> which of course means:
> Of Tron PCBs are a piece to repair the cake. If you wish it with the
> gun of shot, you modify the 2 pots, the transistor of the race 2n3055,
> little the tantalum which is in the medium of the panel, lytisch and you
> go from over there. Word of the council - the comparator the IS the
> 5-Volt-Linie seems, a top is frequently like the rare problem.
> Hope that helps.
> Pat D.
> James wrote:
> > heh...here is how I read alot of that....
> > Tron PCBs sind ein Stück zu reparieren des Kuchens. Wenn Sie zur
> > Schrotflinte sie wünschen, ändern Sie die 2 Töpfe, den Transistor des
> > Durchlaufs 2n3055, das wenige Tantal, das in der Mitte des Brettes,
lytisch
> > ist und gehen Sie von dort. Wort des Rates - die Komparator IS in der
> > 5-Volt-Linie scheint häufig wie das Problem, Spitze ist selten.
> > "Art Mallet - Artfromny - formerly A218@aol.com" <artgames@nycap.rr.com>
> > wrote in message news:TrFVd.35742$vK5.6394@twister.nyroc.rr.com...
> >>Tron PCBs are a piece of cake to repair. If you want to shotgun them,
> >>change the 2 pots, the 2n3055 pass transistor, the little tantalum lytic
> > in
> >>the center of the board, and go from there. Word of advice - the
> > comparator
> >>IC in the 5 volt line often seems like the problem, bit rarely is.
> >>Art
> >>"Rob" <rrandal@pacbell.net> wrote in message
> >>news:z0FVd.8811$OU1.6234@newssvr21.news.prodigy.com...
> >>>I read all your post and what I have done in the past with all my MCR
> >>>systems is buy a
> >>>switching power supply with adapter
> >>>it will cost you around$80.00 and it sure cures alot of problems and
> >>>prevents alot of problems.
> >>>Those MCR boards are very picky about their voltage and the VBat and
> > Reset
> >>>voltage coming from
> >>>the power supply board.
> >>>"James" <rotoquad@***NOSPAMTHANKS***earthlink.net> wrote in message
> >>>news:qLlVd.3$nb1.2@tattler.gsu.edu...
> >>>>The manual does not have it, I see earlier posts that others were
> > looking
> >>>>and in one case a link was provided, but it is now dead.
> >>>>Does anyone have one? Thanks.
> >>>>Reply To: james at retroblast dot com
